It is currently Tue Dec 30, 2025 6:51 am
PostPosted: Thu Jul 02, 2015 10:44 am
Should I fill with JB weld and then grind it down?
Or should I grind the seams first and then JB weld?
Or just coat with JB weld and leave it the way it is?
Thanks in advance
1975 Dodge D100 Utiline
Slant 6, Super Six, Weber 38, 727
Repair work in progress. :)
PostPosted: Thu Jul 02, 2015 11:47 am
I would coat it with JB weld until you have a nice smooth surface, then paint everything with a heavy coat of paint.
PostPosted: Mon Jul 06, 2015 9:47 am
Fresh coat of JB weld and new paint
Ground the seams and other hot spots and three coats of header paint
Need to clean up a little paint that got around my mask job. Then just need to swap with the set that is on the truck
PostPosted: Mon Jul 06, 2015 11:00 pm
Hanibel, that's nice work. Purple intake manifold = better driveability, performance, and more (s)miles per gallon. That's a scientific fact!
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
