It is currently Tue Nov 17, 2026 9:20 pm
 Post subject: Opened the 904 vb
PostPosted: Fri Jul 10, 2015 6:40 am
And found that a couple of screws and 1 check ball missing and a wall appeared to be broken.
http://i280.photobucket.com/albums/kk19 ... l6uvvt.jpg
http://i280.photobucket.com/albums/kk19 ... rv3h2b.jpg
PostPosted: Fri Jul 10, 2015 2:36 pm
If it looks like that wall was taken out with a drill bit someone has tried to shift kit it.
PostPosted: Fri Jul 10, 2015 6:15 pm
It has a b&m shift kit. And does this band look too tight? It has lil to no play
http://i280.photobucket.com/albums/kk19 ... 61odzn.jpg
PostPosted: Fri Jul 10, 2015 9:02 pm
Break the locknut loose, tighten the adjuster finger tight, back it out 1-1/2 turns, and tighten the locknut without turning the adjuster screw.
There is no way to tell without adjusting it.
