It is currently Sat May 16, 2026 1:48 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Apr 10, 2015 7:14 pm
Car Model: 1977 B100 Van
Those are some great links to canister "rebuilds". One thing that isn't mentioned is the purge valve -- the guy on the Jeep site went looking for a faulty vacuum diaphragm and didn't find it, but there is such a diapragm in the purge valve. If the purge valve is faulty (torn or hardened or holed diaphragm, for example) and doesn't work, there'll be problems. Easy enough to fix on a canister without a built-in purge valve (just replace the valve) but harder on a can with an integral valve.
Thanks for the clarification.
Still, I’m a little confused.
My van is a ’77 w/ a stock setup.
The can is the same as the one pictured on the jeep site (3 ports, no built-in purge valve, and the "car bowl" port is capped).
Carburetor is a NOS Holley 1945 Economaster and the correct year replacement for my application.
I don’t have nor need to add a purge valve, it’s "built-in" the carburetor, right?
"Hey, I like that paint job you got. What they call that--sorta a cross between Piss Yellow and Puke Green, ain't it?" -- Bob Falfa
PostPosted: Sat Apr 11, 2015 10:55 am
Sort of, yeah. Does your new carb have an extrernal bowl vent?
PostPosted: Thu Jul 23, 2015 3:24 pm
Well i finally did the fuel line mod, added the the 3 nipple fuel filter.
Rebuilt my charcoal canister and hooked it up.
Finally got some hot weather and what a difference in starting.
No more Bitchy starting problems.
Thanks Dan for posting this info.
Wish I had done this 7 years ago.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Fri Jul 24, 2015 3:31 pm
Hoorah for successful fixes!
Users browsing this forum: No registered users and 29 guests
