It is currently Sat Nov 28, 2026 1:28 am
PostPosted: Sat Jul 25, 2015 12:08 am
Car Model: 1974 Dart Swinger 225
Which master cylinder should be in my '74 Swinger with 4-wheel drum brakes? I'm getting conflicting info from parts shops and also from the shop manual. The manual says the master cylinder bore should be 1+1/32" for drum brakes and 15/16" for disc brakes. It also has the two attached figures. Clearly there was some printing mistake because conflicting information is given. The MC that was installed in my car looks like the asymmetrical one in Fig. 1 but it has a 15/16" bore. So I'm assuming the symmetrical MC shown in Fig. 2 is the correct one for drum brakes. Can anyone confirm this?
PostPosted: Sat Jul 25, 2015 12:35 am
Same reservoir size is drum/drum
15/16 is for disc power brakes
1 1/32 is for manual brakes (drum/drum & disc/drum)
So you need a 1 1/32.
If you have drum/drum & power; I don't know......
PostPosted: Sat Jul 25, 2015 10:26 am
Car Model: 62 Valiant
are you sure? im under the impression that manual brakes need a smaller piston diameter to increase hydraulic advantage.
PostPosted: Sat Jul 25, 2015 8:47 pm
Manual brakes have more leverage at the pedal.
PostPosted: Sat Jul 25, 2015 8:49 pm
If you don't hit the floor with the smaller MC, you will get more leverage that way too.
