It is currently Sat Nov 28, 2026 12:57 pm
 Post subject: Mad Max Header pics
PostPosted: Wed Jul 29, 2015 2:49 pm
Headers for Max:) Snakes everyplace aaaaaaaahhhhhhh:)
PostPosted: Wed Jul 29, 2015 2:58 pm
Gorgeous! Fenderwell headers for a Slant A-body - might be a first?
BTW, Bonneville Speed Week is cancelled due to junky salt conditions. Might go for Sept 12-15 event if salt improves.
Four words: Master cylinder heat shield.
Slant on,
PostPosted: Wed Jul 29, 2015 3:02 pm
Will do a heat shield and headers will bee ceramic coated inside and out.
PostPosted: Wed Jul 29, 2015 4:18 pm
Very nice Mark!
PostPosted: Wed Jul 29, 2015 5:41 pm
Hardest most time consuming,over 200 hrs work, I have done on the whole car.Hope its good for a 10th.I am a better weld grinder than a welder.All primary tubes to the hand made collectors are within 1.5 inches ,34 to 35.5.Got close to a grand in material.Will only bee gratified if car goes quicker.
PostPosted: Wed Jul 29, 2015 6:05 pm
Good job. I know that takes a lot of work.
Will
PostPosted: Wed Jul 29, 2015 6:51 pm
Will,you understand the stupid hours spent trying to go faster.If I won the lottery I would build a turbo motor and bee in the 9s.I dont buy tickets so that Will never happen.Your car has inspired alot of my goals and hard work and my retirement fund beeing depleated.I thank you,,,now.
PostPosted: Wed Jul 29, 2015 7:15 pm
Eeek! You'd spend a grand for a 10th?? Nice.
PostPosted: Wed Jul 29, 2015 7:37 pm
10 second car......100 tenths
10 second car ....$100,000
PostPosted: Wed Jul 29, 2015 7:38 pm
NO,,,,,Hopefully a 10th and a couple hundred hours,yep,I aint all there.Then again I would like to lower my 10 records.
PostPosted: Wed Jul 29, 2015 11:03 pm
Install a 5 speed and you should pick up a few 10ths! :lol: :lol:
PostPosted: Fri Jul 31, 2015 7:47 am
Wow, even if they don't pick up any they look awesome...nice job. Way cool.
The five speed suggestion sounds like a good one too!
Good luck
Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Fri Jul 31, 2015 11:00 pm
As always, your nuttier than the mad hatter! :D
Exquisite workmanship, which I've come to expect from anything you touch, and, like all other over the top endeavours you take on, I'd bet the farm it nets you measurable gains.
Bravo on your progress bringing your Valiant back to life! :bow:
PostPosted: Fri Oct 07, 2016 3:05 pm
nice but I can`t see the pictures of the headers?
