It is currently Fri Nov 27, 2026 10:39 pm
PostPosted: Fri Jul 31, 2015 6:51 pm
What are my options for a manual master cylinder with front and rear discs?
'66 Dodge Dart
PostPosted: Sat Aug 01, 2015 4:16 pm
I used an aluminum master cylinder from a Volare and replaced the proportioning valve with an adjustable one. I made the adapter plate, but you can buy them to convert from the old cast iron to the aluminum ones. I simply cut the rear most 1/2" off the old master cylinder and drilled it for the stud pattern for the aluminum one.
Sam
PostPosted: Sun Aug 02, 2015 1:58 pm
Good info Sam!
I was hoping for an option that was more stock-ish looking. I'll take a look at the aluminum Volare, maybe it'll be more stock-ish than I am imagining.
'66 Dodge Dart
PostPosted: Mon Aug 03, 2015 2:19 pm
Mopar Performance is where I bought my adapter plate years ago when I went from power brakes to manual. I'm also using the aluminum master cylinder.
'78 Volare 225
'67 Charger 318
PostPosted: Mon Aug 03, 2015 3:51 pm
I used a stock 73 up iron master cylinder ...and a stock prop valve
Front disc 75 Dart Rear disc 2000 Ford Explorer
no mods / no problem
PostPosted: Thu Aug 06, 2015 11:02 pm
Sandy what other details can you provide about that master cylinder? What car did it come off of or better yet do you have a part number?
'66 Dodge Dart
PostPosted: Fri Aug 07, 2015 6:20 am
No idea.....
Its likely a stock 75 drum/disc MC.......no modifications
Users browsing this forum: DuckDuckGo [Bot] and 1 guest
