It is currently Tue Nov 17, 2026 1:56 pm
PostPosted: Tue Sep 01, 2015 11:30 am
I recently added the GM HEI Conversion to my truck and now it backfires when under a load. In addition it is running very rich. Should the timing have been adjusted after doing this? I have not been able to find any info on the settings with the HEI conversion. I probably should also look at adjusting the carb but I don't know which to do first. Any help would be appreciated.
 Post subject: Distributor Wires
PostPosted: Tue Sep 01, 2015 3:36 pm
You might have your distributor wires backwards on the HEI module. I know when I did mine I had them reversed the first time. :)
PostPosted: Tue Sep 01, 2015 3:37 pm
Timing and carb setting should remain what they were before the swap. The only thing HEI does is provide a longer dwell period and a hotter spark. That's it.
I second the suggestion that you try switching the pickup wires going to the HEI unit.
PostPosted: Fri Sep 04, 2015 5:24 am
Thanks for the responses, I'll check that out this weekend.
PostPosted: Wed Jan 06, 2016 7:15 am
Thank you again for the suggestions on fixing this problem. I just got back to working on the truck and I found by back-tracking through everything the the back-firing was being caused by the #5 and #6 spark plug wires being in the wrong locations on the distributor.
PostPosted: Wed Jan 06, 2016 8:23 pm
Car Model: 1964 Dart 270
Way to go, glad you figured it out!! :D
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Thu Jan 07, 2016 5:58 am
You can't beat simple; no tools were abused in that repair.
Users browsing this forum: Google [Bot] and 9 guests
