It is currently Fri Nov 13, 2026 4:58 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Tue Sep 08, 2015 8:23 am
I could NOT find a graph for various TPS movement rates on decel. There is one for TPS movement on accell. I did create a data log of an event where it dies, if I did it right, and will send that to Matt on Monday.
Decel doesn't have a full graph. It only applies the Decel Fuel Amount multiplier any time the TPSdot rate crosses the threshold with the throttle closing.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Sep 09, 2015 4:55 am
Thanks Matt. Would you translate TPSdot for me please.. Distance over time? And, does it vary in any way with speed of closing? I am also wondering it went lean from not having a high enough number on the accel side of the stab.
Sam
PostPosted: Fri Sep 11, 2015 10:39 am
TPSdot is % throttle opening per second. For example, going from closed to halfway open in one second would be 50%/sec.
