It is currently Fri Nov 20, 2026 8:28 pm
PostPosted: Tue Sep 29, 2015 5:53 am
Yesterday i removed the cannister, and capped off all the connections it had used.
Now i want to change my fuel filter, and i see that the current one has three ports.
I'd expect two ports -- fuel in and fuel out.
So what is the third port for, and does it go back to the tank or what?
I want simple.... fuel comes up, and into the carb.
Can i replace it with a simple 2-port filter and cap off whatever the third connection is?
'87 D150 Slant-6 A904 with wooden cap
PostPosted: Tue Sep 29, 2015 1:05 pm
Why? Disabling the canister is not only unsafe if done wrong (which it sounds like you might've), but even if done "right", it's not an upgrade, it's a downgrade.
Discussed in Fuel line mod.
You sure you wouldn't rather have the setup that works best, instead of the setup that is "simplest"?
Users browsing this forum: Ahrefs [Bot] and 15 guests
