It is currently Wed May 27, 2026 6:42 am
 Post subject: Rear end I.D.
PostPosted: Fri Oct 09, 2015 7:27 pm
I'm trying to identify the rear end in my 72 plymouth valiant it has the 225 and 3 speed it has 2.76 gears on the tag on the rear end and has 9X2 inch brakes any help would be great or if it's a measurement that I would take
Old but hopefully a goodie
PostPosted: Fri Oct 09, 2015 7:40 pm
Car Model: 62 Valiant
PostPosted: Sat Oct 10, 2015 10:35 am
NEVJr would you happen. To know the wheel bearing numbers
PostPosted: Sat Oct 10, 2015 1:16 pm
Would you happen to know what dodge car is the same as the valiant I need new panels to fix rust spots
PostPosted: Sat Oct 10, 2015 6:44 pm
im not sure about bearings
depending on the panel, you are probably looking for a dart from 1967 to 70 something, the swinger or gts model, also the plymouth scamp
PostPosted: Sat Oct 10, 2015 7:36 pm
Thank you would any of them be a close match I need right portion of trunk and both rear quarter panels and some inner fenders possibly a roof skin any idea other than another car
PostPosted: Mon Oct 12, 2015 4:57 pm
Got the wheel bearing in and had a nice smooth quiet ride home
