It is currently Fri Nov 20, 2026 6:45 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Tue Oct 13, 2015 11:46 am
A previous comment stated his valves were sloppy causing the head to read hot but not the engine as a whole, my question is would the valve lash have that dig of an impact on the overall temperature read out
Yes poorly adjusted lash can cause a retarding effect to timing which increases heat lingering in top-end, or head, which can elevate coolant temperature above normal. Also a badly corroded water jacket can exacerbate "heat of combustion" retention in casting and form localized hot spots that produce boiling on jacket's surface.
Both less than 50% of antifreeze to water mix, and less than 16 psi radiator cap will lower coolant boiling point in the system as well.
