It is currently Thu May 21, 2026 5:19 pm
PostPosted: Sat Oct 24, 2015 10:18 pm
Say I found a 63 push button trans, and I have a 65 valiant with a slipping transmission. Would I be able to use that pb trans in the 65 with some parts swapping?
PostPosted: Sun Oct 25, 2015 7:57 am
Yes. Swap the valve body, filter and pan. Make sure you don't use a filter from a 66 or later trans.
PostPosted: Sun Oct 25, 2015 8:07 am
Don't "swap" the filter, which would involve installing a used filter—not a good idea. Filter and pan info here.
PostPosted: Sun Oct 25, 2015 6:32 pm
Dan, I didn't mean swaping the filter from the 63 trans. Meant "use the 64-65 filter", and 64 up pan.
