It is currently Mon Oct 12, 2026 2:30 am
 Post subject: Early A Body K Members
PostPosted: Tue Oct 27, 2015 5:55 am
I am working on a 1961 and 1962 Dodge Lancer. I see that the K members are different between the two year models.The '61 mounts the steering box to the frame as opposed to the '62 where the box bolts to the K member.The 1962 also has a more substantial looking engine mount support system.
Can anyone give a reason for this change between model years? Is there a preference for one K member over the other? Will they interchange?
PostPosted: Tue Oct 27, 2015 6:31 am
Major suspension change in 62 that carried thru until 66. 67 and up also different. Not sure if you could put a 62 K frame in a 61 car and use the 62-66 setup. I am sure someone here has looked into that.
Brian
63 Plymouth Valiant Wagon
PostPosted: Tue Oct 27, 2015 10:26 am
I am pretty sure you can swap in the 62 K-frame, which will give you much larger parts availability and a more reliable steering box mount. The LCAs were the same from 62-74, IIRC. Shocks interchange up to 76 A-bodies. 62-up steering box was used well into the 70s on A-bodies many other Mopars.
