It is currently Thu May 28, 2026 2:56 am
PostPosted: Wed Nov 11, 2015 7:02 am
I just bought a 1964 Valiant and the prior owner told me the transmission was leaking from where the pushbutton linkage attaches to the transmission. Now I can confirm that it is leaking for sure. I'm trying to get car back on the road will post pictures soon. Can I purchase this gasket by itself? I did try to search the forum but didn't find. Thanks
PostPosted: Wed Nov 11, 2015 7:27 am
T'Flite Patty's Shop Mart is part of Pat Blais Transmissions
http://www.ebay.com/itm/Torqueflite-904 ... 0773218347
probably an O-Ring
1964 Dart GT
PostPosted: Wed Nov 11, 2015 9:14 am
Thanks ordered today!!
PostPosted: Wed Nov 11, 2015 3:08 pm
While you're at it, guard against other leaks with the pan and gasket info in this thread.
PostPosted: Thu Nov 12, 2015 11:21 am
Inspect the cables closely for outer jacket damage because they will leak fluid out the cable it self, if the cable jacket is burned or cracked thru to the inner core.
PostPosted: Thu Nov 12, 2015 2:00 pm
If the cable's burnt as Doc describes, see here.
