It is currently Tue Nov 17, 2026 9:21 pm
PostPosted: Fri Dec 18, 2015 7:08 pm
I have a 64 dart I use for winter driving.
It is a great car for winter and has saved my butt many time in the snow, thanks to the 7 1/4 shur-grip rear end.
The push button automatic will randomly stick in first for a bit while first driving.
When it finally shifts, it'll do second gear for a split second and end up in third.
I'm guessing a shift valve in the valve body or a sticky governor.
After the initial delayed shift, it won,t do it again that day.
I probably wont mess with it (especially this season) unless it gets worse.
PostPosted: Sat Dec 19, 2015 9:49 am
A fluid & filter change is a great first step.
Be sure to use the correct filter... for a 60-65 "cable" 904... these have 2 oil pumps so look for 2 oil feed holes, in the correct filter.
(or you can add the second hole in the 66 & up filter)
PostPosted: Sun Dec 20, 2015 9:46 am
I'll have to be sure to get the right filter since I didn't know that they have a different filter.
A fluid and filter change helped since it was worse when I first started driving it 14 years ago.
It had 64k miles then but had been sitting and rusted out much of the underside before I bought it.
It now has 84k miles and idles so smooth that I have to look at the ammeter to be sure I don't accidentally grind the starter trying to restart it while it is running.
PostPosted: Sun Dec 20, 2015 10:17 am
Having the later "1 hole" filter in the early 904 could be the cause of your late shift problems...
That is the first thing to check.
