It is currently Mon Nov 16, 2026 8:06 pm
PostPosted: Fri Jan 08, 2016 12:51 pm
make it look cool for a rod project. I know NOTHING about aftermarket old school parts for a slanty. I have one in my 77 Ramcharger but want to gain some knowledge on how to make a slanty look cool for an open no hood rod?
Looking for suggestions.
 Post subject: Does anyone have...
PostPosted: Fri Jan 08, 2016 4:07 pm
Hopefully a Killer Bee can help, if they knew of any pictures of David Erickson's 34 Plymouth that are still online...it was a real mover, not sure the suspension he used either...I think the only thing that grounded it at Medford a few years back was the aftermarket GM tilt column broke and couldn't get it to sit right without a pair of vice grips....
PostPosted: Fri Jan 08, 2016 5:51 pm
Car Model: '23 T-bucket
That '35 looks pretty nice in the rain. I'm thinking a heavy clear coat over the patina, and drive the heck out of it.
I think I'd also locate a suitable front axle, perhaps with a little drop to it. Maybe an original '35 Plymouth axle. Run the parallel leafs, find yourself a rear sump pan and pickup for a mildly built slant, backed by a 904 auto. You would probably have enough room under the floor for an A518 (?) overdrive trans, but that would require a rather hard to find, v-8 trans to slant pattern adapter. That would give you an overdrive, and with a Ford 8.8 and desirable gears out back, it could be a nice cruise-mobile.
You can get, made in the U.S., a single four-barrel intake, and a twox1 barrel intake from Offenhauser. I think Clifford still makes an intake for three, side-draft webers, butr Clifford's customer service is sketchy.
There's Australian companies that make a few nice intakes, as well.
Doug Dutra, right here on this board, offers a true, split cast iron exhaust setup. You can buy both manifolds from him, or cut and modify your existing manifold, with a purchase of just the front manifold from him.
Offy also offers a cast aluminum, polished, finned valve cover.
T'were me, I'd run the twin one-barrel intake, using mid-late fifties Ford, Holley 1904 carbs, with the glass float bowl for some eye candy. Some say the glass is dangerous, but that's something for a different discussion.
Roger
PostPosted: Sat Jan 09, 2016 5:19 am
Very cool project. I have dreamed of doing the same car with a Slant. Welcome to the site!
PostPosted: Sat Jan 09, 2016 7:15 am
Here is a 1938 Plymouth with a slant. Granted it's not in an open engine bay, but fits nicely.
PostPosted: Sat Jan 09, 2016 2:36 pm
Not to pick nits, but that's a '39.
obliquely-inclined state of mind
PostPosted: Sun Jan 10, 2016 6:44 am
You are correct sir. I should have double checked the automotive archives shelved just behind me here in the man-cave's nerve center. LOL
I saw this car on side of road one day five or six years ago, employed file footage labeled at the time as a 1938 presumably from sale sign hung on window. By the time I got home down loaded the camera I probably forgot the exact year, or the addled widow selling off some unwanted iron knew from nothing. I suspect the first scenario to be closer to the truth being my addled brain as the culprit.
At any rate, I suspect not much changed by 1939 to Plymouth engine compartment dimensions that slant was so nicely slid into. I don't recall if fire wall was modified to accommodate the longer slant or not, and don't recall if it was an automatic or standard.
PostPosted: Sun Jan 10, 2016 7:41 am
My 51s slant pics in my signature. Beware of cheap chrome valve covers.
51 Plymouth Cambridge with / 6
PostPosted: Mon Jan 11, 2016 6:15 am
My 33 Ply conv, 34 Ply sedan and 35 Dodge pickup (early body)have too short a distance to easily squeeze in the slant between the radiator and firewall.
Suggest you find a complete car and check that distance for your swap by looking at a complete car first to be able to size up the work involved.
If anyone has any of the above family of cars with a slant or has seen one I'm all ears and eyes for info or pictures.
PostPosted: Sun Jan 17, 2016 4:42 pm
Car Model: 1964 Valiant
The 23-inch Dodge/Plymouth flathead is a compact design. The block of the 201 - 230 six has about the same compact dimensions as the Toyota Supra 7MGE, which has a similar small bore (3.25 vs 3.27-inch). You'd need to do some custom work with fabricating the radiator support, which it appears that car doesn't have. A slant six swap has been done before. The P15-D25 forum might be a good place to look. Its relatively common to swap in the 25-inch flathead in these cars - the 25-inch six was standard in Canadian cars, the frames were the same. I think that where the 25-inch six would fit, a slant six can be coaxed to fit as well.
