It is currently Mon Jun 15, 2026 6:21 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Fri Jan 08, 2016 6:11 am
I would shoot for 9.5:1 SCR and degree that cam at 100 installed, for a purely street car. Easier to stay away from detonation and will still make plenty of power.
PostPosted: Fri Jan 08, 2016 6:44 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Wow! Lots of great info. Thanks, guys! I'll do some poking around on the forums and research over the weekend. I'm definitely curious on a 0.100" overbore, so I'll be scouring the forum for builds to see what other guys have done. I'm completely new to engine building (if that wasn't obvious enough), so I really appreciate all the advice. I'll keep you posted on what I decide.
Chuck and the Flying Valiant
 Post subject: Yep...
PostPosted: Fri Jan 08, 2016 4:24 pm
This gives a pretty wide berth for fudge factor...I ran the numbers based on a 40 overbore just for fun....
If you 280/270 is ground per catalog standard at 111LSA and 4 degrees of advance:
-a 10.3SCR cam installed straight up will produce an 8.03 DCR (OK for regular, can run more timing on plus/super, but not needed) - recipe is .055 deck height, and a 53 cc combustion chamber...
Indexing the cam to 100 for more low end torque and limiting high end overall power puts the DCR at 8.5:1 (need Plus or Super every other tank as a standard)
Bumping SCR down to 9.73.1 but keeping the 100 degree centerline puts the DCR at 8:1.... (still a good number)
Bumping the SCR down to 9.55:1 (deck height .095)and same centerline
puts you at 7.89:1 DCR and will be fine on regular and a little more timing can be dialed in at higher octanes if desired.
You may need to recurve the distributor if heading in these directions.
Cheers!
PostPosted: Sat Jan 09, 2016 5:22 am
Degreeing most 225 Slant cams at 99-102 will give best power overall and gives very little sacrifice (if any) in top end power. I tried 96 once and I could tell the top died off a bit.
111 LSA is way too wide for a Slant cam. I think I ordered my 280/270 with 108 LSA.
9.5:1 and degree at 100 still make most sense to me.
PostPosted: Sun Jan 10, 2016 8:05 pm
Wow! Thanks, DI and Lou!
Thanks so much for running the numbers! I did forget to mention I have a recurved distributor tailored for this build by someone on the forums. I really wish I could remember who.
I've been playing with the idea of maybe just going big and doing a .60 or .100 overbore since I've got everything apart and maybe just going big. What do you guys think of that idea?
Thanks again for the number run. I've seen the dynamic compression ratio calculators before, but I'm really not sure how you get all the right numbers for a Slant. Mind showing how it's done?
Really, this is great stuff. I really appreciate it!
PostPosted: Mon Jan 11, 2016 5:12 am
I'd be interested as well. Have tried to input the numbers into the Wallce calculators and must be doing something wrong or the numbers are backwards or something. Keep getting either negative compression ratios or extremely low numbers. Doing something wrong I am.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Mon Jan 11, 2016 6:59 am
Okay, good. I'm glad it's not just me! I was about to check myself into the looney bin! :lol:
PostPosted: Tue Jan 12, 2016 5:37 am
I have never used those. Just previous experience here. Maybe DI or someone else can chime in.
PostPosted: Tue Jan 12, 2016 6:32 am
I have used them numerous times on both slants and sbc. I use multiple calculaters to verify results. If the numbers are not repetable they are not valid.
I have used Wallace and Silvolite.
My last slant build (280/270 Erson 9.25CR) was based on a lot of calculator work. I find it important to know what you want to achieve and what fuel you wish to use. I chose regular fuel .....and got what I wanted.
My last sbc build led to the use of an oval track grind in a drag type application ......because of the converter and gear selections and the narrow rpm band . Without the calculators I doubt I would have ended up with the winning, dependable, cheapo small block setup that got me 2nd in a series dominated by huge block aluminum BBCs.
You MUST have all the numbers. If you dont know where the piston top/deck height is you are just guessing. You should do you compression ratio work and head work first.......and then figger your cam timing......and then your ignition timing.
PostPosted: Tue Jan 12, 2016 7:57 am
Or just throw together whatever you have laying around and spray the snot out of it. :D
PostPosted: Tue Jan 12, 2016 10:31 am
I like your attitude!
PostPosted: Tue Jan 12, 2016 2:58 pm
I resemble that remark. :lol: :lol: :lol:
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
