It is currently Tue May 19, 2026 1:21 am
PostPosted: Wed Jan 13, 2016 3:20 pm
no one repops this. is the small block 904 lines the same or will work????? thanks
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
PostPosted: Wed Jan 13, 2016 3:26 pm
The routing of the la lines would be different than the slant ones due to oil pan, exhaust routing, etc... but if you are handy with a flare tool and a tubing bender I see no reason you or someone else could not bend up your own.
PostPosted: Thu Jan 14, 2016 4:32 pm
Car Model: '64 Valiant Convertible
From the rad... straight back; the other... back, over, and back; then they 90 up, and head back behind the exhaust manifold
Then they 90 down, then back at a 40-45 along the engine to bell housing bracket
They are secured in a piece of tin that bolts to the engine/bell housing junction
And then on back to the transmission
They are secured to each other on the vertical at the front of the motor, and in the tin bracket at the back of the motor. I've experienced a couple small variations, but that might be who did it on what day or which model.
Neil
PostPosted: Thu Jan 14, 2016 7:18 pm
none of your photos work.........
PostPosted: Fri Jan 15, 2016 2:55 am
thanks, I will have t give it a try.
PostPosted: Fri Jan 15, 2016 11:02 am
thanks for the photos. helps a bunch!!!!!
