It is currently Wed May 13, 2026 12:05 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
 Post subject: rubber bands
PostPosted: Tue Jan 12, 2016 1:21 pm
Some folks never use them and apparently have no rattles. My only data point is that I just installed a set, used the rubber bands, and have no rattles.
b
https://tinyurl.com/yynpj4v2
PostPosted: Sat Jan 16, 2016 4:37 am
PostPosted: Sat Jan 16, 2016 6:03 am
PostPosted: Sat Jan 16, 2016 6:07 am
PostPosted: Sat Jan 16, 2016 10:17 am
matv91 - Thank You! I am going to tear into the brakes this afternoon and those pages are Extremely Helpful!
1964 Dart GT
 Post subject: bolt size?
PostPosted: Mon Feb 08, 2016 12:08 pm
What is the bolt size and length/thread size for the bolt that holds the caliper bracket (slider type) to the spindle on these disc brakes? Mine are 11" rotors, slider style. It's a fine thread pitch I know that much, about 2-2/5" long, but does anyone have the exact specs for this bolt?
thanks so much,
Brian
PostPosted: Mon Feb 08, 2016 12:22 pm
Is it 1/2-20 thread, 1 5/8" long? That sounds about right, want to confirm.
brian
PostPosted: Mon Feb 08, 2016 3:07 pm
I can't see the threads with everything put together, but the holes in my spare M-body caliper brackets (11" rotor) are 1/2". The head on the bolts installed on my car is 3/4", which also implies a bolt diameter of 1/2". I don't recall if they were coarse (1/2-13) or fine (1/2-20), but fine seems more likely.
1-5/8" sounds about right for bolt length. My spare brackets look to be about 3/4" thick where these bolts pass through, if you take the countersink into account.
Kinda fuzzy info, but I hope that helps.
Escape Velocity Racing
 Post subject: Thanks!
PostPosted: Tue Feb 09, 2016 11:06 am
Confirmed, it is 1/2-20, 1 5/8" long, full threads (although given the thickness of the bracket, I don't think you need full threads as long as the non-threaded part is less than the bracket thickness).
b
PostPosted: Mon Feb 15, 2016 3:08 pm
UPDATE: Finally got a chance to get back to my brakes! I pretty much used everyone's suggestions. Applied BrakeQuite goo on the back of the pads, added the Rubber Band things in the proper place, checked wear on the slider brackets against a Brand New Pair. No significant wear whatsoever! :D The Retaining Clips were the major problem! The ones that came with the calipers were flimsy, thin, and cheaply made. I replaced them with a slightly heavier stamped metal type that work well!
Top: Old
Bottom: New
1964 Dart GT
PostPosted: Tue Feb 16, 2016 6:43 am
Gotta love this Forum!
So,... Did it work? :D
PostPosted: Tue Feb 16, 2016 8:06 am
[quote]Gotta love this Forum![/quote]
Quite Now and Stops like it never has before. :lol:
1964 Dart GT
 Post subject: Re: 74 tsb
PostPosted: Mon May 07, 2018 5:38 pm
 Post subject: Re: tsb
PostPosted: Mon May 07, 2018 5:41 pm
PostPosted: Mon May 07, 2018 5:43 pm
