It is currently Fri Nov 27, 2026 4:07 am
PostPosted: Sat Jan 23, 2016 11:16 am
Car Model: '64 Valiant Convertible
Greetings,
so my '64 Valiant temp gauge barely moves off the left edge. I grounded the sender wire with the key switch on and the gauge casually pegs to the right. I used a laser temp gauge on the thermostat housing and read 185 F.
I'm thinking a new sender. Any other ideas?
Does anyone know a part number for a replacement sender?
Thanks! Neil
PostPosted: Sat Jan 23, 2016 4:00 pm
The early sender has larger thread (1/4"-27 dryseal) than the late sender (1/8"-27 dryseal), and your '64 does not use the early (up-to-'63) sender. It uses the later small-thread sender, Standard № TS-205.
 Post subject: Thanks Dan
PostPosted: Sun Jan 24, 2016 9:20 am
Thanks for clearing that up for me. My other convertible was a '63. Obviously I'm mis remembering the good old days. Thanks for the part #.
Neil
