It is currently Tue May 26, 2026 3:07 pm
Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Mar 16, 2004 7:47 am
Man, I cant imagine how much fun it would be to drive all the way out to Vegas and see all the Mopars! Unfortunetly.... I got final exams coming up soon, and it will be the same story for the next few years :(
Maybe In a few years I'll start going, once Ive graduated 8)
On the bright side, this gives me lots of time to work on the car!
PostPosted: Tue Mar 16, 2004 9:10 pm
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
Hit a snag tonight. I must have hit the fuel tank sender with the diff. The fuel line is loose at the plate and dripping. Is it welded in? Some kind of seal? Can I get one or fix mine tomorrow? JB Weld???
AND I got the wrong drums from the parts house. 4.5" bc. I replaced everything but the backing plate in the brakes. I even installed Stainless Steel lines I've had lying around for a year or so.
Drums I think I can get tmorrow. I pick up my shortened drive shaft in the morning. The sender is another story. That's all that's left.
HELP!
Mike
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
PostPosted: Tue Mar 16, 2004 10:18 pm
Originally I think it was just crimped on. I had a leak there too with mine when I replaced the hoses, I must of yanked a bit too hard on the rubber line when removing it and seperated the small length of steel tube coming out just a tiny bit.
I'm not sure if JB Weld will hold under gas. I had someone weld mine (may of used some sort of special solder?) together and its holding so far. IIRC the metal circle that it attaches to is galvanized.
I don't know how desperate you are but new senders are availible for roughly $100 and I bet you can find a place thats willing to overnite one to you. Junkyards would be a good bet too.
Just be careful when removing/attaching the rubber hose to it.
PostPosted: Wed Mar 17, 2004 6:42 am
Mike,
Any sender from A-bodies '63-76 will work, so that opens up lots of possibilities for you. There's the overnight route, or just a local junkyard should have one, eh?
JB Weld would almost certainly work, and silver solder would be your best bet, although even radiator solder would work. Use a propane torch to heat the metal, put on some flux (or use flux core rad solder), and melt the solder onto the part.
PostPosted: Wed Mar 17, 2004 11:20 am
Yes, the sender tube is soldered into the cover plate, they do crack and drip.
Drain the fuel level to under 1/2 tank, pull-out the sending unit assy. and resolder it. It's pretty easy to do.
Keep "thrashing", you will get there!
Doug
PostPosted: Wed Mar 17, 2004 12:53 pm
I would completely drain the tank or pull out the entire sender before soldering it. If you heat up the plate/tube to solder, you'll be heating up the entire tube behind it that extends into the tank, and thats a bit dangerous with something as volatile as gas. Also you might melt the rubber sealing ring between the tank and the sender.
PostPosted: Wed Mar 17, 2004 1:17 pm
HOLY #$%^! :shock: I totally meant for any soldering to be done w/sender outside the car. I didn't think of anyone trying it with the sender in place and gas dripping...
 Post subject: Fear not!!
PostPosted: Wed Mar 17, 2004 3:18 pm
:D Let's see.
I got my drive shaft back fro Cannon with 1 7/8" removed. Won't know if it's right till tonight.
Got up early this morning and dropped the tank. The whole thing. Took it to a radiator guy I've used for years. He soldered it up for $25.
All of the brake parts are in. The parts guy is pulling his hair out. First he ordered 10" drums with 4.5" BC. Took those back this morning. I know I should always check. At lunch I went to pick up the drums, 4" BC 9" drums. :? I'm going by after work to see if he got it right this time. Those suckers were steep.
Still on schedule.
1965 Barracuda /6
PostPosted: Wed Mar 17, 2004 3:37 pm
Just incase the parts store guys don't come through, I have a pair of 10" SBP drums, brand new, sitting on the floor doing nothing. You can have them for what I paid + shipping (which I assume you would want overnite, not going to be cheap, but probably not too bad since I'm just east of SanFrancisco....) I recall looking around locally for these and no one could get them for me.
Just incase you need the part #: autospecialty (TRW brand) AD8344 10" x 1 3/4" (Be careful, there were also 10" x 2 1/2" drums used on b/e bodies as well).
 Post subject: Stand by
PostPosted: Wed Mar 17, 2004 3:53 pm
I'm going by the parts store at 4:30. If they're not right you'll be the first to know. What's the cutoff for instate fedex/UPS? If I completely lose my mind I'll jack up my wagon and borrow those. Come to think of it They were the drums from the 8 3/4 I got from you Lou. See what happens when I try and cut corners.
Mike
1965 Barracuda /6
PostPosted: Wed Mar 17, 2004 4:51 pm
Just called a UPS store and they said 4:30. I'll try fedex next if need be.
PostPosted: Wed Mar 17, 2004 8:23 pm
Sounds like getting them off the wagon is by far the easiest. I knew I had sent drums with you...
Good job on the tank. Now you'll have a good test run of all your mods on the way to Vegas... :D
PostPosted: Wed Mar 17, 2004 8:32 pm
No good. I ran by my next best source. No good Discontinued!!! I have one more source in the morning. I didn't think 10" SBC 1 3/4 drums would be that hard.
1965 Barracuda /6
 Post subject: I wonder?
PostPosted: Wed Mar 17, 2004 8:37 pm
Could I put the 9" drum brakes on the 8 3/4 rearend? I know, It's stupid. Just might work
Mike
1965 Barracuda /6
PostPosted: Wed Mar 17, 2004 8:38 pm
Mike,
I couldn't believe how hard they were to find as well. I tried more then a handful of different parts stores/distributors and they either didn't show a listing or showed them as discontinued. I got mine from www.megapartsusa.com
Click on catalogue, then the first link "AA Mopar" then about 10 down is the rear brake drum section.
