It is currently Mon Nov 16, 2026 12:48 pm
PostPosted: Mon Feb 22, 2016 7:09 pm
I have an 833 overdrive trans that came with a Hurst shifter and rods.The rods are obviously much too short so I assume they were deigned for a midship shifter mounting.My trans has the shifter mounting location at the rear of the output shaft housing.
Can anyone shed some light on the correct shifter and or rods that I should look for ?
PostPosted: Mon Feb 22, 2016 7:33 pm
Have you looked at the 4 speed article?
http://www.slantsix.org/articles/4-spee ... speed1.htm
It may shed light on the mystery, it sounds like may be you have one version of the transmission and a set of shift rods for the other...
