It is currently Mon Jun 22, 2026 3:31 am
PostPosted: Sun Mar 06, 2016 3:40 pm
My gear has some odd wear, so need a new bronze gear for this build.Thanks.
Andrew
Wife's: 64 Valiant
PostPosted: Sun Mar 06, 2016 4:14 pm
When that happened to me it was a cam gear problem (twice).....and it cost me a bundle.
Is this a Comp Cam?
PostPosted: Sun Mar 06, 2016 4:24 pm
Yes, comp cam......I know, I have heard it before.LOL, this I hope is all that is wrong, I mean. to keep an eye on.
Andrew
Wife's: 64 Valiant
 Post subject: Doc...
PostPosted: Sun Mar 06, 2016 5:18 pm
Doc was the last source for hardened oil pump gears... Not sure I'd go to bronze, especially if the gear sacrifices a bit...I'd prefer the iron one and put a magnet in the oil pan....
If he has any left, you will need to know if the rotor shaft is keyed or not...
PostPosted: Mon Mar 07, 2016 7:25 am
OK, not bronze then.....LOL, I might be robbing the one from another engine.
Wife's: 64 Valiant
PostPosted: Tue Mar 08, 2016 5:11 am
Andrew,
Here is what I do: I take a stock used pump from a previously running motor, clean it up on the outside, and run the darn thing. I have done this every time since learning about the failures in the early 2000s and have had no problems with gears, ever. I put one or a few washers under the stock relief spring to adjust max pressure to be around 60 psi. I also use stock reground cams (Oregon), although I used a few Crane and Mopar cams bought before 2000. I haven't even taken a used pump apart yet as I believe that might disturb the internal workings.
Slant on,
