It is currently Thu Nov 26, 2026 8:18 pm
 Post subject: hub cap remover
PostPosted: Sun Mar 06, 2016 9:24 pm
Car Model: 1964 Valiant
What works well to remove the 10-1/2 inch hub caps from the trucks and vans? I had no success with a paint can opener. I know of the special tools but which one works well for the least cost?
PostPosted: Sun Mar 06, 2016 9:30 pm
Doesn't the screwdriver end of the lug wrench work?
PostPosted: Sun Mar 06, 2016 9:39 pm
The OEM lug wrench was missing. Would #5216018 work ? These 10-1/2 inch caps don't leave enough room for a screw driver to work.
PostPosted: Sun Mar 06, 2016 11:01 pm
If I can't find a tire iron, a flathead screwdriver has always worked for me.
PostPosted: Mon Mar 07, 2016 6:50 am
The only dedicated hubcap remover I have ever seen was for a VW Beetle. I would think a thin screwdriver would do the trick. Or maybe bonk it with a rawhide mallet? :shrug:
PostPosted: Mon Mar 07, 2016 12:44 pm
I have an old flat head screwdriver bent 90* at the tip that I keep in the trunk at all times. I also have a small piece of rubber I use under the pivot of the screwdriver to keep the wheels from getting dinged up.
PostPosted: Sat Mar 12, 2016 6:35 pm
I got the OEM tire tool for the truck.
PostPosted: Fri Mar 25, 2016 4:53 am
Came across a picture of this tool in Stockel - Auto Mechanic's Fundamentals.
Here's one:
It's a glorified screwdriver!
exoJjL
