It is currently Wed Jun 24, 2026 9:25 pm
 Post subject: head studs?
PostPosted: Mon Mar 07, 2016 8:48 am
Ok, so I am planning the parts to reassemble the engine when I get it back from the machine shop. I had read on another post that milling the head and block will require studs replacing the head bolts. I have a total of about .130 milled from the head/block. I'd hate to buy studs if I don't need them. I'd rather spend the money elsewhere. Has anyone had problems using stock head bolts in setups like this?
PostPosted: Mon Mar 07, 2016 9:06 am
You can use head bolt washers and stack 2 if needed, but 1 should do. Get a set for small block Chevy and you will have plenty. :D
PostPosted: Tue Mar 08, 2016 5:14 am
You do not need head studs. The bolts are plenty strong at least up to 12:1 and can be reused as long as they are not plastically deformed (drastically overtorqued). In most cases, you won't need the washers either, but that can vary block to block. I have never used washers (up to 0.200" mill) and I guess I've been lucky.
PostPosted: Tue Mar 08, 2016 8:06 am
Thanks Lou, I'll see what happens without them, but I ordered some .110 thick ARP washers just in case.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
