It is currently Sat Jun 20, 2026 11:01 am
PostPosted: Wed Mar 09, 2016 3:26 pm
I have a 87 Dodge d150 with a 3.7 l slant six. My fiance was changing the exhaust manifold gasket and two bolts were seized. Can't find another exhaust manifold and was wondering what other motor has the same exhaust manifold set up. Or any ideas???
PostPosted: Wed Mar 09, 2016 3:37 pm
Car Model: 62 Valiant
which 2 bolts?
PostPosted: Wed Mar 09, 2016 4:00 pm
Pretty much any slant six passenger car, truck, or van manifold (and most industrial applications, too) made post 1974 (or whenever they switched to the open choke pocket) will work. You can order new ones from China through parts stores, Dorman, Rockauto, or eBay for about $300 plus shipping.
PostPosted: Wed Mar 09, 2016 4:13 pm
Where are you? We may have someone close to you who has one. :D
PostPosted: Wed Mar 09, 2016 4:20 pm
I'm from glouster Ohio. And I am at a total stand still. Can't find another slant six motor that has a exhaust manifold on it and don't know what other motor has the same slant six exhaust manifold set up
PostPosted: Wed Mar 09, 2016 4:23 pm
I can't help you but would like to extend a welcome to you. I also have an 87 D100 2 wheel drive with the slant that I'm swapping a late model 40/20/40 interior into it.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Wed Mar 09, 2016 5:10 pm
The only manifold that will fit is a Slant-6 item, and if your '87 has an oxygen sensor (many of them do) screwed into the rear wall of the central collector of the manifold, the manifold you install must have the provision for the sensor (many of them don't). If you have the cash and want the project to be done once and for all (and not be dragged out by finding new problems with old manifolds, etc) then buy this new manifold and this gasket set.
If what's broken isn't actually something on the manifold but one or more of the studs that hold the manifolds to the head, that's a different set of questions and answers.
