It is currently Tue Jun 23, 2026 6:44 am
 Post subject: Wheel Width Questions
PostPosted: Thu Mar 18, 2004 4:30 pm
I've got a 73 dart with the stock wheels. I'm planning on swapping to the large bolt pattern and putting some larger and wider wheels on the dart. what are some of you guys running on your cars? I was looking under there in the back and theres only about an inch or two between the tire and leaf spring. How wide can i go on the back or the front? I was thinking about 16 or 17's and maybe eight inches wide but thats looking pretty improbable. Anyone got an idea or experience with this? I know about the leaf spring relocation kit from mopar but i'd like to stay away from that if i could. Am i stuck with a narrow tire and wheel combo?
PostPosted: Thu Mar 18, 2004 5:39 pm
235 60 14 on the front 245 60 14 rear on 14 x 8" rims
 Post subject: wheel width
PostPosted: Thu Mar 18, 2004 11:35 pm
my tires are not as wide as the previous person...
I am using 195-70 x14 on front and 225-60x14 on the rear both on stock ralley wheels 14x6....there is still room to go wider....
do you have small bolt pattern?...mine were big bolt pattern(4.5" circle) and its just a plain /6 4door 1973 Dart.....
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
 Post subject: Bolt Pattern
PostPosted: Fri Mar 19, 2004 7:32 am
73's with discs have large bolt pattern while 73's with 4 wheel drums have the small bolt pattern. Right guys?
PostPosted: Fri Mar 19, 2004 8:13 am
Online
Yes.
I can also say that 8" wide rims are no problem on an A-body if the offsets are right. 9" rims should be OK, but more challenging.
