It is currently Wed Sep 30, 2026 1:40 pm
 Post subject: Valves
PostPosted: Mon Mar 28, 2016 6:19 am
Anyone know where I can get a set of P4286783 (I) and P4286784 (E) high flow valves for my /project?
Thanks
PostPosted: Mon Mar 28, 2016 9:42 am
http://www.moparpartsgiant.com/parts/mo ... 86784.html
http://www.moparpartsgiant.com/parts/mo ... 86783.html
http://www.chicagoconnection.us/index.p ... cts_id=334
http://www.diyporting.com/angles.html
PostPosted: Mon Mar 28, 2016 10:15 am
Thanks man they have exactly what I needed!!!!
PostPosted: Mon Mar 28, 2016 1:20 pm
Oops,
They say discontinued now. Any other guesses???
PostPosted: Mon Mar 28, 2016 4:56 pm
AFAIK, most of the MP stuff for Slants is long gone unless it also happens to fit a small block or big block.
Engnbldr valves still pop up once in awhile, but I think he was retiring too.
Ferrea used to have a drop in that would work in Slants, but I do not have the part numbers.
PostPosted: Mon Mar 28, 2016 5:03 pm
http://sivalves.com/2016-SI-Catalog.pdf
Page 22.
PostPosted: Mon Mar 28, 2016 5:15 pm
The engnbldr exhaust valves are still on E-Bay, but he is definitely retiring
PostPosted: Mon Mar 28, 2016 5:29 pm
say discontinued
I kind of figured that, but what you were asking about was,,,standard valves with a back cut,,
that is why I posted a how to link for cutting a valve back cut with a drill press, or any shop that does port flowing could also put in a back cut for you.
so unless the standard valves in the head you have now are badly burnt, have them reground and a back cut added. You will have exactly what you were asking for.
the Engine Builder and Ferrea valves listed are OS valves,
PostPosted: Mon Mar 28, 2016 7:02 pm
Awsome, my shop says they can do the backcut on the valves. Thanks for the grind post. I'll get it to them.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 13 guests
