It is currently Sun Jun 21, 2026 8:43 pm
 Post subject: Pulley questions
PostPosted: Sun Apr 03, 2016 10:46 pm
My original vibration damper bit the dust tonight. The outer ring is completely separated from the inner ring.
Questions:
(1) Recommendations for a source for replacement? Damper Dudes? What about THIS truck damper on eBay? My vehicle is a 76 truck, so that eBay damper should work for me, right?
(2) I am contemplating upgrading to a factory 120 amp alternator. The 120 amp alt has two pulley sheaves. The 120 amp alternators I have seen on V-8 applications all used double alt belts. If I upgrade to the 120 amp alternator on the slant in my truck will I have to run a double pulley on the water pump? Any suggestionson how the belts run on a slant with a 120 amp alternator?
Thanks!
PostPosted: Mon Apr 04, 2016 12:05 am
When are you going to have a 120 amp load?
I'd think you'd only need 2 belts if your alternator was putting out a bunch of amps. Otherwise the load on the belts is going to be what it is now.....
PostPosted: Mon Apr 04, 2016 3:56 am
From bulletin 09-16-76 july 26 1976. REVISD later on. 4071061 is listed for heavy duty truck cast crank manual tranny. Must us cankshaft screw and whasher.
PostPosted: Mon Apr 04, 2016 7:08 am
Dampers different between auto and manual with cast cranks. More info later...
PostPosted: Mon Apr 04, 2016 7:41 am
Thanks! This truck was built in June of 76, so I really don't know if it is a cast or forged crank. It is definitely an automatic, though. I appreciate the info!
 Post subject: Re: Pulley questions
PostPosted: Mon Apr 04, 2016 9:14 am
I've used those on a variety of engines, all with automatic transmissions. They work well. Price is nice and seller is reliable. Pounce on it.
No. Slant-6 applications did not use double alternator belts, just V8s.
PostPosted: Mon Apr 04, 2016 9:18 am
Excellent! Thanks yet again Dan! Three sheave heavy truck harmonic balancer has been ordered.
PostPosted: Mon Apr 04, 2016 3:37 pm
http://www.slantsix.org/forum/viewtopic ... 20393f16cc This thread has newer bulletin
PostPosted: Mon Apr 04, 2016 4:38 pm
Dang, thanks Mat! And thanks to Craig for posting that info! Good stuff. Since my truck was buit in June of 76, I have no idea if it is a cast or forged crank. However, since I am running an automatic it doesn't matter. Yay.
PostPosted: Mon Apr 04, 2016 5:54 pm
Cast crank blocks are easy to tell. They lack the large casting numbers of the earlier blocks.
PostPosted: Mon Apr 04, 2016 7:16 pm
Really! I didn't know that. Thanks!
