It is currently Fri Jan 02, 2026 7:10 am
 Post subject: Rocker ratio?
PostPosted: Thu Apr 14, 2016 6:27 am
I have a mechanical cam, lifters etc. I'm checking the cam degree. What is the rocker ratio on factory rockers?
PostPosted: Thu Apr 14, 2016 7:28 am
Car Model: Toad Wagon
1.5 > 1
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Apr 14, 2016 7:46 am
Thank you
Last year I got myself all screwed up doing this. Where I live - in the motorcycle world - you measure valve timing at the valve. What I learned after wasting a bunch of time and confusing myself is that on a slant 6 you measure cam timing at the lifter.
--> The Diesel Corvette <--
PostPosted: Thu Apr 14, 2016 7:49 am
Yep. Do Not try to degree a cam off the rocker arm.
Are you using the intake centerline method or just valve opening/closing?
PostPosted: Thu Apr 14, 2016 7:53 am
Idk. Lol I've never done it with a wheel before. I have always used dot to dot so this is my first attempt at this. How should I do it?
PostPosted: Thu Apr 14, 2016 8:01 am
http://www.compcams.com/technical/instr ... es/145.pdf
Cam degreeing starts on page 8.
Isky's instructions: http://www.iskycams.com/cam-degreeing.html
Searching for "cam degreeing by intake centerline" gives lots of good results.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 10 guests
