It is currently Sat Jul 18, 2026 8:57 am
 Post subject: Early A Gas Tank Help
PostPosted: Wed Apr 13, 2016 6:51 pm
Car Model: '64 Valiant Convertible
Greetings,
my '64 Valiant gas tank is pretty rusty inside. I'm thinking of replacement.
Does anyone have any experience or wisdom on the subject? Sources?
I noticed while looking on ebag and Amazon that none of the tank pictures showed a vent nipple near the filler neck inlet. My tank has a nipple there which connects to a vent tube tied to the top of the filler neck just inside the fender.
I couldn't swear my existing tank is original. And my filler neck has been brazed at some point in the past. No idea if that part is stock either.
Any help is appreciated. Thanks!
Neil
PostPosted: Wed Apr 13, 2016 8:56 pm
I replaced mine for about 100$ from rock auto I believe
 Post subject: Hey Traviss....
PostPosted: Wed Apr 13, 2016 9:06 pm
Yours is a '63, is that right?
Did the tank you bought have a nipple for the vent near the filler neck? And is there a nipple at the top of the filler neck (in the trunk)?
Thanks
PostPosted: Thu Apr 14, 2016 8:18 am
I bought one off eBay for my 1964 Dart GT, but the vent tube is on the filler neck, not the tank. Replace the tank strap and filler neck gasket (at tank) when you do the job. (also gasket at sending unit, but I replaced my sending unit at the same time!)
1964 Dart GT
 Post subject: What I Learned...
PostPosted: Thu Apr 14, 2016 3:03 pm
Here is the tank I removed from my car with the mystery nipple??? Maybe '60-62??? I dunno. It's wrong. Shouldn't be on my '64.
Here is a trunk at Wildcat Auto Wrecking. You can see the vent from the top of the filler neck loops around then pops through the trunk floor and...
As the filler neck goes into the tank, the vent line just dies off right there and would just drip fuel down onto the leaf spring or exhaust pipe on its way to the ground.
Learn something new every day, if you try.
PostPosted: Thu Apr 14, 2016 6:27 pm
Mine is like the Wildcat picture, but you would be very hard pressed to get fuel to come out of it! It is just a Breather, and bends well above the filler neck!
1964 Dart GT
PostPosted: Wed May 04, 2016 6:24 am
Replace it all while you're in there, if you can. Even the sock (inlet screen). Eventually you'll have to, and it's easier to do it all at once. And any rubber fuel line between the tank and the carburetor.
Oh, and mind the ground strap between the sender and the hard line. Replace that, too.
PostPosted: Wed May 04, 2016 7:02 am
I discovered the filler neck grommet (small, for 1 3/4" filler necks)(4002010) is still an active number available from your local mopar dealer.
I wish I had tested the sender/gauge position before I installed the new sender. Then I would have a better idea as to fuel level/needle position.
One thing for sure, when the needle stops moving... the car stops moving shortly thereafter.
