It is currently Fri Jan 02, 2026 7:42 am
 Post subject: Valve spring
PostPosted: Wed Apr 20, 2016 8:54 am
Hi, so i bought the engbuilder valve springs and i dont know what the install hight is supposed to be can anyone help me out?
Thanks
PostPosted: Wed Apr 20, 2016 9:05 am
Stock height is fine. Do you need to know that dimension? Also, did you get retainers? Stock retainers don't fit those springs correctly. Here's a post of mine showing stock retainers in those springs and the proper retainers.
http://slantsix.org/forum/viewtopic.php ... ner#299802
PostPosted: Wed Apr 20, 2016 9:16 am
Yeqh i need the deminsions, i didnt get any retainers yet because i wasnt sure if i would, what kind of retainers should i get?
PostPosted: Wed Apr 20, 2016 9:43 am
1 11/16" is stock installed height if memory serves. Check your FSM. I'm seeing 1.65" for 340 replacement springs which is close. Retainers can come from same plave as the springs or you can pay more elsewhere.
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
