It is currently Fri Nov 13, 2026 6:56 am
 Post subject: safety trans shield
PostPosted: Wed Apr 20, 2016 2:54 pm
I need advice on trans flex shields for ihra rules, I see the tci aluminum trans shield, I don`t know if this is the best? also I only see a sb flex shield steel can these be modified to fit a slantsix pattern and pass safety inspection? any help
PostPosted: Wed Apr 20, 2016 3:51 pm
I can't remember who, but someone used to make one for the Slant.
Pretty sure modifying a V-8 one is a no-no. :D
PostPosted: Thu Apr 21, 2016 4:25 am
thanks , I don`t know how strict they are going to be , this is going to be the first full season for IHRA rules, if I read them right anything over 6.99et in the 1/8th you need both.
PostPosted: Thu Apr 21, 2016 9:17 am
Are they asking for SFI approved?
I was able to make my own Kevlar flex shield and get it passed by my sactioning body.
PostPosted: Thu Apr 21, 2016 10:53 am
no sandy they haven`t asked but they did make me replace my belts because of exspired dates , I`m hoping to increase the blower drive and this hopefully put me into the 6.99ets which if I am reading the rules for super pro brackets I need flex plate and trans shields. I was thinking if I had a sb flex shield and made flat bar exstention if it could pass.
PostPosted: Thu Apr 21, 2016 11:38 am
6 Pack Dart
Check out Tom Waters in Florida, That is who made my SFI approved metal flexplate shield for the slant six. Metal ones you get 5 years before recertification.
Richard
PostPosted: Thu Apr 21, 2016 6:11 pm
is he on this site?
PostPosted: Thu Apr 21, 2016 10:48 pm
6 Pack Dart
No http://racecarpartsdepot.com/ Should get you to his contact info.
Richard
PostPosted: Fri Apr 22, 2016 10:14 am
I have gotten SB SFI flexplates for the LA engine and modified them to fit the slant - They were sfi Approved when new - not sure now?
Here's a blurb on what I did:
http://www.slantsix.org/forum/viewtopic ... &start=195
PostPosted: Fri Apr 22, 2016 3:41 pm
I have the v8 sfi flex plate but the flex shield is my problem.
PostPosted: Fri Apr 22, 2016 3:42 pm
who carries a sfi damper for a slantsix, I know bb dodge can be used.
PostPosted: Sat Apr 23, 2016 5:36 pm
Here's what I used on ruster and the 69 dart if you need a sfi and stock type pulley location.
http://www.slantsix.org/forum/viewtopic.php?t=18147
Usually can be found on eBay
PostPosted: Sat Apr 23, 2016 7:02 pm
finial got answer back from track rep, I need the sfi damper, I have the romac coming. I need the trans shield at 6.99et and the flex shield at 6.50et. now I just need my first sub 7sec/et.
