It is currently Tue Jun 23, 2026 5:02 am
 Post subject: bent pushrod repair?
PostPosted: Sat May 07, 2016 3:31 pm
Car Model: 1965 Barracuda 'S' auto
I blew it and torqued down my valvetrain with 1 pushrod not seated in the lifter, bent it pretty good. I was able to pound it straight with just a ripple of a tweak. Can I run it or is that an absolute no-no? Does anyone got a spare mechanical pushrod they want to donate?
I didn' t buy it, I built it.....
PostPosted: Sat May 07, 2016 3:34 pm
I have plenty of spare hyd. if that in any way helps
PostPosted: Sat May 07, 2016 3:50 pm
Put in a dead-straight pushrod. They're cheap and it's easy and it'll avoid problems down the line.
PostPosted: Sat May 07, 2016 3:52 pm
Don't run it unless you want to tear it apart again in short order.
PostPosted: Sat May 07, 2016 6:36 pm
Noted. Does anyone have a solid lifter ball/cup pushrod they can spare? Ill compensate...Thanks. So.Cal.
PostPosted: Sat May 07, 2016 7:38 pm
If it's a stck cam and valvesprings running it will probably not hurt a thing. Bill's stock motor in his Dart has had 2 in it for years that I straightened with a hammer just to get him going. :)
