It is currently Fri May 22, 2026 2:58 pm
PostPosted: Wed May 11, 2016 1:28 pm
Does anyone have the measurement for where the shifter is located in the car in relation to the firewall or bellhousing face? How far away is it?
Casey
PostPosted: Wed May 11, 2016 5:30 pm
Its kinda pricey but this might help you.
http://www.classicindustries.com/produc ... m1227.html
~Nic
PostPosted: Thu May 12, 2016 2:23 pm
I'm looking for the info for a transmission swap other than a stock 4 speed. I'm guessing that piece just nests into the contours of the floor for location rather than placing it a certain distance from the firewall.
Any 4 speed A body owners out there who could take a quick measurement?
PostPosted: Mon May 30, 2016 11:15 am
I measured 19 inches from the bell housing/transmission interface to the center locating bolt for the hurst shifter. This is on a a833 od a/f trans.
Hope this is of some help.
PostPosted: Tue May 31, 2016 5:35 pm
Thanks! So that is basically to the base of the shift lever where it comes through the floor?
PostPosted: Wed Jun 01, 2016 3:06 pm
Yes, When the transmission is in neutral the shift lever is in the vertical position coming thru the floor. The bolt I spoke of is directly below the lever.
Also measured a stock 3 speed with floor shift, same thing 19 "
PostPosted: Wed Jun 01, 2016 5:49 pm
Thanks. That helps me confirm what I need for my 6 speed conversion.
