It is currently Fri Dec 26, 2025 9:50 am
Post new topic  Reply to topic  [ 72 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Thu Jul 30, 2015 2:45 pm
How about the side draft manifold used on Clark Motorhomes in the early to mid sixties.
Brian
63 Plymouth Valiant Wagon
PostPosted: Thu Jul 30, 2015 3:12 pm
That's № 6 in my list on the first page of this thread.
PostPosted: Thu Jul 30, 2015 8:21 pm
What about the marine one for when they layed the engine flat?
Dave
1972 d-100 parts truck
PostPosted: Sat May 14, 2016 9:20 am
a horizontal 6? How did they do oil pan? I guess a slight angle would be needed to keep oil from pooling behind the pistons? I saw a Lynx single weber side draft intake on a slant, that was one crude looking intake: straight shot into 3 and 4, about a 80 degree branch going to 1-2 and 5-6. tried to trade it for a stock 2bbl and a guarantee it would work better than that piece but lady had to ask her dad, never heard back.
I didn' t buy it, I built it.....
PostPosted: Sun May 15, 2016 12:44 pm
So number 1 cylinder would "cry" every time the brakes were applied??
PostPosted: Sun May 15, 2016 9:43 pm
I would think 1 and 6 would be bawling through out the cycle. Looks like a lean condition design. It ran ok, I heard it but never drove it. Young lady didnt know what she had in there as she claimed her dad just retrieved it from the "top of a hill" of a neighbors property. I equate that to a barn find or a "hadn't seen pavement in 20 years" story.
PostPosted: Mon May 16, 2016 11:53 am
See here and here and this paper is worth the $ if you want all the details.
PostPosted: Mon May 16, 2016 3:13 pm
I always thought it would be cool to install a horizontal AKA "Space Saver" marine engine under the floor of a van or wagon and make a mid-engined sprots car.
The intakes on the space saver engines look like they make a 180 degree bend up and over the valve cover, which would make adjusting the valves on those engine QUITE a chore, considering the manifolds would have to be removed to get the valve cover off, then reinstalled to run the motor for adjustment, then removed to put the valve cover on, etc... AND the nuts are on the bottom of the motor.
Still, seeing that would almost be enough to make me buy a boat!
PostPosted: Mon May 16, 2016 3:34 pm
I think the space saver would fit mostly under the floor of a B-van, but there would likely have to be a small hump and some lost ground clearance.
The drawings show that the intake manifold isn't in the way of the valve cover, but moving the carburetor temporarily might make a valve adjustment easier.
PostPosted: Mon May 16, 2016 3:54 pm
Ah! I missed that. Still, I think I would run a hydraulic lifter setup if I had one of these. You would definitely want a remote oil filter setup.
PostPosted: Wed May 18, 2016 1:23 pm
No, sir. See p. 3 of the first PDF I linked.
PostPosted: Wed May 18, 2016 1:48 pm
Thanks for posting those Dan! Very interesting info. Now I really think it would be a fun project to put one of those engines mid-ship in a van!
Users browsing this forum: Ahrefs [Bot] and 21 guests
