It is currently Thu Jul 16, 2026 12:26 am
 Post subject: NHRA class question
PostPosted: Sun Jun 05, 2016 1:07 pm
Car Model: 62 Lancer GT
I read an old post about Mike Jeffries setting the V/SA national record. I have seen the Buzzin' car. But if V/SA is 22 lbs per cubic inch and assuming the engine is a 225 does that mean the vehicle weight is 4950? somethin' aint right in my thinkin'.....Maybe its not a slant?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
 Post subject: Re: NHRA class question
PostPosted: Sun Jun 05, 2016 2:46 pm
That is 22 lbs per hp, not cubes. Not sure what the NHRA "factored" HP, is.
PostPosted: Sun Jun 05, 2016 3:40 pm
Thanks Charlie
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Sun Jun 05, 2016 3:43 pm
I used to know that once...
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Sun Jun 05, 2016 7:54 pm
Not sure what his HP is right now. He got some taken away a few years ago, but has been "awarded" some back a couple times since then. Last I knew I think the Dippy weighed about 3350.
PostPosted: Mon Jun 06, 2016 4:11 am
To clarify, Mike is not racing the Buzzin Half Duzzin car (68 Valiant). He runs a Diplomat (1980?) in V/SA, as Zilla mentioned.
Best,
PostPosted: Mon Jun 06, 2016 5:19 am
Just an example. When I raced my 65 Valiant in stock eliminator, back in the "70"s, it ran Z/SA, at 25 Lbs/HP. Had a 170 engine rated at 101 HP (was not refactored). Car had to weigh 2525 lbs, and hit the scales at 2530 lbs.
PS: It could run mid 16's with a best of 16.2 on a 17.36 index.
PostPosted: Mon Jun 06, 2016 7:33 am
Thanks for the replies.... some day I might try to enter an event just for the experience
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Mon Jun 06, 2016 8:27 am
The Stocker is "Buzzin' Half Duzzin' Too". :lol:
PostPosted: Mon Jun 06, 2016 6:13 pm
That can be an expensive endevor. Stock is far from stock.
PostPosted: Mon Jun 06, 2016 6:27 pm
As long as you're in a lower class and not trying to set records, V can be pretty reasonable, especially if you stumble on a car someone else gave up on.
PostPosted: Mon Jun 06, 2016 7:42 pm
Not trying to set records...
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Tue Jun 07, 2016 12:13 am
If you really want a V car Mike might be tempted into selling you his.
