It is currently Thu Jun 25, 2026 6:36 am
 Post subject: 450-500hp?
PostPosted: Tue Jun 07, 2016 5:13 am
Hi.
I'm gonna start to build a new engine for my -80 Aspen and would like to get 450-500hp. Any help I can get would be nice. I will use a roots supercharger e85.
Thanks.
PostPosted: Tue Jun 07, 2016 8:10 am
Welcome!
At the boost required to make 450hp you're better off with a turbocharger or a screw compressor than a Roots blower.
While there are some very fast carbureted turbo cars many (most?) use alcohol injection as a supplemental fuel and detonation suppressant. EFI I feel is a good choice as it gives a lot more control over fuel and ignition which helps keep pistons and head gaskets healthy.
I highly recommend spending some time in the boost and nitrous section and reading about head gaskets, o-rings and head studs.
PostPosted: Tue Jun 07, 2016 9:16 am
You may want to give serious consideration to beefing up brakes and suspension with that kind of power.
PostPosted: Tue Jun 07, 2016 9:25 am
Online
Being conservative?
Only 450-500 HP?
PostPosted: Tue Jun 07, 2016 11:20 am
Being conservative?
Only 450-500 HP?
To start with :D
PostPosted: Tue Jun 07, 2016 11:21 am
Yes I will upgrade because I think the 100hp is almost to much for the brakes and suspension.
PostPosted: Wed Jun 08, 2016 10:44 am
Does anybody know wich block is stronger or if they are equally strong.
the one with 3 or 5 freezeplugs?
PostPosted: Wed Jun 08, 2016 10:54 am
In all honesty, there really isn't much difference between blocks.
What blower are you going to use?
Member terry littlejohn is using a 6-71 and can probably be a lot of help to you. :D
PostPosted: Wed Jun 08, 2016 12:00 pm
I was actually thinking of using a 6-71 :D
 Post subject: ...curious
PostPosted: Wed Jun 08, 2016 9:04 pm
...is this a strip car or a street car? 450+ hp from a slant is awesome. If a strip car, people will be impressed (as they should), but if a street car, people will be in awe, jaw-dropping power from an I6....love it.
https://tinyurl.com/yynpj4v2
PostPosted: Wed Jun 08, 2016 11:47 pm
Terry might be using a 4-71.
Seymour had a buddy with a 4-71 back in the late '90s. IIRC, it made well over 400 back then.
 Post subject: Re: ...curious
PostPosted: Thu Jun 09, 2016 2:24 am
It will be a street car :D there are a couple of people in the city close to where i live that say the slant is a crappy engine(they have 320-360 V8 with under 350hp)So I want to se their reaction when the car is ready.
PostPosted: Thu Jun 09, 2016 7:57 am
The Slant 6 seems to respond very well to boost. We hope your project goes very well! There are a few other cars in Scandinavia (Finland included) on this site.
PostPosted: Thu Jun 09, 2016 1:05 pm
Here is an interesting site that may help.
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
