It is currently Thu Jan 01, 2026 12:50 pm
 Post subject: 1920 rebuild
PostPosted: Sat Jun 25, 2016 11:46 pm
hi guys. I rebuilt the carb but have the dreaded peice left over. It looks to be the idle compensator gasket. It's a small yellow oring. any idea where this goes? It's not in the manual.
Thanks
PostPosted: Sun Jun 26, 2016 9:55 am
It goes behind the bimetallic hot idle compensator, which in turn is behind the small rectangular sheetmetal cover on the driver's side of the carb.
PostPosted: Sun Jun 26, 2016 12:43 pm
My type doesn't have those peices.The casting has those ports covered as well as the screw holes.
PostPosted: Sun Jun 26, 2016 1:33 pm
Then you don't need that O-ring.
PostPosted: Sun Jun 26, 2016 2:26 pm
I thought it came off the the carb and not from the kit. I must have been wrong. Thanks for putting my mind at ease. Now, to get rid of the vacuum leak at the trottle rod.
