It is currently Tue May 19, 2026 6:59 pm
 Post subject: drive shaft
PostPosted: Sun Jun 26, 2016 4:06 pm
When I installed my drive shaft, the tranny was empty of fluid. Can I pull the drive shaft with the tranny full, does fluid pour out, should I drain the tranny first? I have a drain plug on my tranny pan.
thanks all.
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Sun Jun 26, 2016 4:40 pm
You will lose some fluid if you pull the driveshaft, but of the torque converter stays full it won't be much.
 Post subject: You could...
PostPosted: Sun Jun 26, 2016 5:17 pm
If you jack the rear axle up and put on stands, and leave the front tires on the ground or close to it, you won't lose as much fluid the tilt will keep most of fluid toward the front of the tranny...
PostPosted: Sun Jun 26, 2016 6:08 pm
Yep, jack it up from the rear. I've taken the drive shaft and speedo gear unit out and lost less then a spoon or so of fluid.
 Post subject: thanks guys...
PostPosted: Sun Jun 26, 2016 6:11 pm
sounds like a plan.
b
