It is currently Thu Jan 30, 2025 9:44 am
 Post subject: edelbrock carb id needed
PostPosted: Tue Jun 28, 2016 10:40 am
number on left front is 1415 941
it seems to large for my slant bogs upon big throttle. I have been searching and can not locate these numbers anywhere.
wondering what the cfm is
slant six's RULE!
http://www.usajon.com
PostPosted: Tue Jun 28, 2016 10:57 am
1415 isn't listed in the Edelbrock Performer Series carburetors as I'm sure you've found. The 1405 is the 600 CFM manual choke carburetor. If you measure the venturi major diameter and the throttle bore diameter I can tell you the CFM. FYI, the 600 CFM carb has venturi diameters of 1-3/16" for the primary and 1-9/16" for the secondary.
Users browsing this forum: Ahrefs [Bot] and 15 guests
