It is currently Thu Jan 01, 2026 10:51 pm
 Post subject: New oil pump questions
PostPosted: Sun Jun 12, 2016 11:13 am
Hello, I have ordered a new oil pump for my 64 225, but the new pump have 5 bolts and dont have a stand tube. Is it ok like that or I need to put my tube un my new pump ? If yes how to ?
Thank you
PostPosted: Sun Jun 12, 2016 12:37 pm
others should chime in soon, but the 5-bolt is fine with the correct gasket and there is a WIX oil filter that has a built-in stand pipe.(Wix 51805)
1964 Dart GT
 Post subject: Yep...
PostPosted: Sun Jun 12, 2016 12:56 pm
If you want to transfer the standpipe over then all you need is a 1" wrench and unscrew it from your old pump, unscrew the "stubby" pipe from your new pump and swap them out.
Which oil pump did you buy?
PostPosted: Sun Jun 12, 2016 1:08 pm
I bought the sealed powers 5 bolts oil pump.
If it's not dangerous I will prefer to not use the stand pipe because it's really messy to do oil change with it.
I use wix 51515.
PostPosted: Sun Jun 12, 2016 6:20 pm
I have run most all of my Slants with no stand pipe.
PostPosted: Sun Jun 12, 2016 7:44 pm
Ok thank you
PostPosted: Wed Jun 29, 2016 10:53 am
Hello, engine is back on place, runs good, but the new pump look to leak by the big bolt, do I need to re-torque it ?
PostPosted: Wed Jun 29, 2016 12:33 pm
6 Pack Dart
The gasket may not match the pump. Some of the gaskets don't match the pump, odd as that may seem.
Richard
PostPosted: Wed Jun 29, 2016 1:24 pm
But it look dry arround the gasket, it look like the oïl is comming from the bolt.
PostPosted: Wed Jun 29, 2016 2:42 pm
Do you mean the plug where the oil pressure switch is supposed to be?
 Post subject: Yikes!
PostPosted: Wed Jun 29, 2016 3:58 pm
That's what it looks like to me in the bottom picture...
Time to pull that plug and have an oil pan ready...clean it up and either a) install the oil sensor in that spot (wires to the oil light in the dash cluster), or b) put some sealant on the plug and reinstall, let cure, then top the oil back up....
PostPosted: Thu Jun 30, 2016 2:58 am
Ok oil is already drop because I have a leak on the timing cover. I Will glue it on right stuff. My oil sensor is on the engine block. Thanks
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
