It is currently Tue Sep 29, 2026 4:15 am
 Post subject: Nitrous plate
PostPosted: Wed Jun 29, 2016 8:18 pm
Hey everyone, im looking to put a plate system together and i have the offy intake and i was wondering if i needed to cut the 4 holes out to work with the plate, i also have a 4 hole carb spacer on it, any help is appreciated thanks.
PostPosted: Thu Jul 07, 2016 3:11 pm
I ran mine with the 4 holes in the carb adapter and with them cut out. There did not seem to be much difference.
How big of a shot you wanting to try? :D
PostPosted: Thu Jul 07, 2016 5:05 pm
125 for sure but i was thinking about 150 :twisted:
PostPosted: Thu Jul 07, 2016 6:06 pm
I made gobs of passes on a 150 shot. Bad things happened when I tried 175.
Start at 50 until you get used to it. Stuff happen quickly when you spray. :shock:
PostPosted: Fri Jul 08, 2016 3:40 am
I had the same problem. But eventually I did get to about a 225 shot, on a 170 with a fogger system.
PS: It didn't make too many passes at 225, before it ate a stock piston.
66 Cuda at 3250 lbs, with a stock 170 short block (just a cam). 12.905 at 101.85 mph
