It is currently Mon Sep 28, 2026 11:14 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Jul 15, 2016 8:46 am
Josh,
That relay idea is a great one and I will use it, for sure. Thanks for adding it to the mix; it should be a big improvement over what I had in mind,
THANKS!
Bill
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Fri Jul 15, 2016 8:50 am
[quote="Dart270"]Sounds like a reasonable idea, Bill. People use timing retard changes to help launch cars all the time, but usually with programmable timing devices.
Go for it!
Lou[/quote
Yhanks, Lou... This is the kind of information I was looking for. I just need some reasssurance that I am headed doen the right path...
Bill]
PostPosted: Fri Jul 15, 2016 9:02 am
keep everything how you have it already. set the 2 step, should take less than 10 minutes to get it ready. bring it up on stall and watch the boost go up.
Junior, Thanks for the good advice, This is the MSD 6-AL-2 box I have:
https://www.msdperformance.com/products ... parts/6421
I don't know that it's programmable, but it does have 2-step capabillity built in, so, I should be okay. There's a turnable knob behind a rubber access plug to set the rpm.
I'll let you know if it works..
Bill
PostPosted: Fri Jul 15, 2016 9:54 am
Trigger the relay to turn the retard on with the brake light switch. Put the brakes on and the timing retards, brakes off normal timing. Easy as pie. :D
PostPosted: Fri Jul 15, 2016 10:19 am
Thanks, Slantzilla! That sounds like a capital idea! I don't know how many amps this MSD two-step actuator would use, and whether the brakelight circuit would need a higher-capacity fuse for that. Do you know?
Bill
PostPosted: Wed Jul 20, 2016 10:31 am
The amp draw for the 2 step is very low, and you are only activating the coil on the relay so that is pretty small too. I ran a similar deal on my '66 and never took out a fuse.
PostPosted: Wed Jul 20, 2016 12:57 pm
Thanks for the good information, Slantzilla!
Bill
PostPosted: Mon Aug 01, 2016 5:57 am
My 2 step is a button on the steering wheel. It's been a while since my last track outing (just bought my first house!). My car is a 5 speed so the last time I just 2 stepped at 3000rpm which built between 5-10psi depending how long I sat there and that was netting me a 1.81 sixty with some moderate tire spin dumping the clutch. Precision 62/62 turbo 63 ar housings the spool was always pretty solid but the 2 step should help ya build some boost.
Kev
