It is currently Tue May 12, 2026 10:16 am
PostPosted: Fri Jul 29, 2016 3:50 pm
I just bought a pair of these: http://www.manciniracing.com/arespbrset.html These are the brackets that the leaf spring shackles hang from. I have to admit I'm a little disappointed in the quality. This is the picture from the website.
And this is what I received:
In the website's picture I can see the tube isn't welded 360°, and it doesn't really have to be. The vertical load is supported by the tube extending through the bracket; the weld is just there to hold it in place. Still, I was expecting more coverage than the ~75° I got. I actually go around corners in this car, and I'd like to be more comfortable this bracket isn't going to flex under lateral loads. Also, the picture shows them as painted. How hard would it have been to go just a little further and make the parts as advertised?
I know this isn't a huge deal, and it's not worth raising hell and demanding a refund. These will probably work just fine for most people, and I'm more than capable of breaking out a can of Krylon (after I fire up the MIG welder to satisfy my own sense of over-engineering). I just expected a little more for $65 a pair.
As one of my friends said when I complained about this: "Elderly man disappointed with quality of online product but not enough to return it; will fix problem himself for the price of griping to anyone who will listen. More at 11." :P
Escape Velocity Racing
PostPosted: Fri Jul 29, 2016 3:52 pm
The older I get, the more this describes my attitude towards the world in general. Thanks for the product review and warning.
PostPosted: Fri Jul 29, 2016 3:55 pm
The funny part is that I'm only 30. I'm gonna be insufferable in a couple more decades.
PostPosted: Fri Jul 29, 2016 5:32 pm
Buy yourself a set of sliders from Summit....same price....better everything.
PostPosted: Fri Jul 29, 2016 5:52 pm
I'm only 38 and poeple already call me an old bastard. :lol:
PostPosted: Sun Jul 31, 2016 7:34 pm
Mancini Racing should have been your 1st tip off to a problem! :lol:
I'd send them back and make your own!
1964 Dart GT
PostPosted: Mon Aug 01, 2016 6:49 pm
That looks most likely stronger than the original to me, especially if that is seamless tubing. I would run it, or maybe for extra super insurance put a short bead of weld on the other side of the tube from the current bead.
PostPosted: Mon Aug 01, 2016 8:25 pm
If for some reason you keep them, definitely re-weld! That looks like a Crap Job in the picture! (and I am Far From A Professional Welder!)
1964 Dart GT
PostPosted: Tue Aug 02, 2016 10:13 am
I agree on the tubing quality. The tubing on both original mounts is split wide open at the seam, while the Mancini ones are seamless.
The actual weld quality looks fine to me, it's just lacking in quantity. The traverse speed might've been a little fast, but the penetration looks good. I'm going to continue the existing bead on the inside of the bracket as far around the tube circumference as I can.
PostPosted: Tue Aug 02, 2016 11:04 am
Looks like a Tig weld. I'd bet it's pretty tough.
PostPosted: Thu Aug 04, 2016 4:22 pm
It probably is strong enough, but for $65 they could have spent another 10 seconds on each side and everyone would have been much happier! :? :?
PostPosted: Fri Aug 05, 2016 7:00 am
My thoughts exactly.
