It is currently Fri May 22, 2026 7:59 am
 Post subject: Small diameter filters?
PostPosted: Tue Aug 02, 2016 6:54 pm
Anyone have any info pro or con on the smaller diameter filters that are out there for our engine. Looks like they would give a little more room around the distributor to work. Wondering how much filtration you would be giving up?
Rick
PostPosted: Tue Aug 02, 2016 9:33 pm
The smaller diameter filters are available short and long just like the bigger filters. You'd have to cut one open to compare the actual filter size, but the difference probably isn't enough to worry about. Unless your engine is filthy inside the filter is not getting near its holding capacity during normal oil change intervals. A better quality small filter is probably preferable to a big cheap filter. Wix 51516 or 51516XP is the small diameter tall filter and is what's used on the SRT-4.
PostPosted: Wed Aug 03, 2016 4:12 pm
Thanks Josh. I may run them on my truck then.
Rick
PostPosted: Wed Aug 03, 2016 6:34 pm
Cool idea. Thanks for the part numbers, Josh.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 13 guests
