It is currently Wed Nov 25, 2026 2:19 am
PostPosted: Sat Aug 06, 2016 8:36 pm
I have a 64 valiant convertible. Both left and right Rear turn signals work but only left brake light works. Anyone know what I should look at first to rectify?
PostPosted: Sat Aug 06, 2016 9:19 pm
Right brake light bulb would be where I would start.
PostPosted: Sat Aug 06, 2016 9:45 pm
The same filament in the same bulb is used for the brake light and rear turn signal functions; the OP says the left and right rear turn signals both work, so it's not a faulty bulb. It's a faulty turn signal switch. The power for the brake lights goes through the turn signal switch; that's how those bulbs do double-duty as brake/turn signal. When the switches wear out, one of the first symptoms is loss of one brake light. Install a good quality new turn signal switch and the problem will go away.
PostPosted: Sat Aug 06, 2016 11:06 pm
And then I would wait for Dan to correct my too-quick-to-judgment and incorrect diagnosis. 8) I am getting over a nasty flu bug or I would have remembered that the filament for the brakes and turn signal is the same. I will go back to lurking mode until my head is completely clear. :oops:
PostPosted: Sat Aug 06, 2016 11:21 pm
Thanks for the advice. I assumed it may be something related to a dual function switch. I will try to find a new switch. One more question. What if you are born on second base ?
PostPosted: Sun Aug 07, 2016 1:18 pm
That work has already been done for you -- just click the red "new turn signal switch" text in my post above, and you'll be taken to the right page to source a good new switch.
PostPosted: Sun Aug 07, 2016 2:46 pm
Same assumption except a life time of whining being robed of a triple.
