It is currently Wed Sep 30, 2026 11:41 pm
 Post subject: Rear mount turbo
PostPosted: Mon Aug 08, 2016 8:09 pm
Has anyone done a rear mount turbo set up? Im thinking about putting a turbo on my car but i dont want to take my nice header off
PostPosted: Tue Aug 09, 2016 2:46 am
Brian Mimken did in his Duster. I'm sure he'll chime in. :wink:
Go to this thread in Social Corner. He was featured in Car Craft recently.
http://www.slantsix.org/forum/viewtopic ... highlight=
PostPosted: Tue Aug 09, 2016 5:26 am
great story, even if the ets are not great, with the hp and torque this car must be a blast too drive on street or road course!!
PostPosted: Tue Aug 09, 2016 5:09 pm
Terry, I like the rear mount setup but if I had to do it over again, I would have gone fuel injected vs. carbureted. If it was a drag only car, carbureted would not be an issue. Driving it on the street is another thing, I seem to constantly have to walk a fine line with my carb tuning. Carbs can be hard enough naturally aspirated to get tuned, then throw in the boosted aspect and it gets a little more difficult tuning wise.
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Tue Aug 09, 2016 5:16 pm
I am currently upgrading my brakes and making some suspension tweaks for doing some road course driving. I did an autocross with it once, but the turbo kept kicking in right at the wrong moment at those slower speeds. Also, I found out the hard way about the need for a baffled/modified oil pan for that kind of driving. I suspect it would be a real blast on a road course. As far as daily driving, I have fallen in love with the turbo. Decent fuel mileage when at cruise, and the beast comes out on demand when desired.
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Tue Aug 09, 2016 8:08 pm
nice. fuel injection helps with a lot, I would love to try turbo if I could find an inexpensive injection system for my budget. :(
PostPosted: Tue Aug 09, 2016 8:10 pm
Several people, including me, found it challenging to autocross my '87 Chrysler Conquest. I understand.
PostPosted: Tue Aug 09, 2016 9:49 pm
Im in the process if putting the fitech power adder efi on my slant right now, my plans are to run it at on atleast 12 lbs of boost, my compression is at 9.1 right now
PostPosted: Wed Aug 10, 2016 2:03 am
I had pretty good luck with my two FWD Turbo cars (89 Lebaron GTS and 05 SRT4). I much prefer RWD cars though.
PostPosted: Fri Aug 12, 2016 6:48 pm
Brian
Was that just the ubiquitous turbo lag complaint or maybe related to a rear mounted turbo, or?
PostPosted: Fri Aug 12, 2016 7:51 pm
It was a little of both. Autocrossing usually involves delicate throttle inputs and you rarely get out of first gear. It is not about horsepower, its about handling and braking. If you have participated in one, you know what I am talking about. My rear mount setup does have some lag, and depending on the layout of the course, I would have boost kick in just as I was getting ready to brake in some areas. It did not diminish the fun I was having, it made it a wee bit more complicated at times. I'm sure I can either tune it or make a turbo change that would be friendlier for autocrossing.
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Sat Oct 22, 2016 4:53 pm
Look into this?
http://fitechefi.com/products/30004/
Also interested in this all as well because I'm getting ready to overhaul my slant and I'm definitely looking to force feed some air into it.
PostPosted: Sun Oct 23, 2016 6:07 am
thanks! interesting product.
