It is currently Fri Aug 14, 2026 9:51 pm
 Post subject: Oil flow routing.
PostPosted: Wed Aug 23, 2006 7:49 pm
Is the oil pressure swich port on the dirty or clean side of the filter?
PostPosted: Wed Aug 23, 2006 7:59 pm
Clean :shock:
PostPosted: Thu Aug 24, 2006 10:17 am
Here is the flow diagram for the SL6 oiling system.
PostPosted: Thu Aug 11, 2016 7:11 am
Sob the flow would be........pickup to pump, pump to filter, filter to block?
PostPosted: Thu Aug 11, 2016 7:26 am
Yes, but the pickup screws into the block so it's pan, pickup, block passage, oil pump, oil filter, block passages to bearings.
Users browsing this forum: Amazon [Bot] and 13 guests
