It is currently Sun Nov 15, 2026 6:20 pm
PostPosted: Tue Sep 13, 2016 11:08 am
Hello brothers in slant. I am deep in the swap from 1bbl to the Super Six on my 66 dart. I have recently begun a real rough idle when I first start it up. Lasts for 5 - 8 minutes until it is warm, and ultimate;y goes away. It is not cold here, so that is not the issue. And I drive it every day, so it is not sitting.
However this only started happening after I cut off the EGR ufo disk. . What I did was removed it, cut off the disk, and cut the little plunger stem (which is now loose and just sitting there). Then I flipped the whole thing 180 degrees and reinstalled it. Can that have anything to do with a rough cold idle? Note I did not remove the entire EGR bracket, I cut it off and left the plate that covers the exhaust holes (I assume)
tThe only other thing I did recent was tried to adjust the fuel mix at the carb. it is the carter bbd. I turned both screws all the way in (lightly), then back them both out 2 1/4 turns, then started it up, got it hot, then starting turning both in at the same time till it dropped, then backed it out about 1/2 turn. I tried to back them out until I heard something, but nothing ever changed and I thought the screws were about to fall out. So I redid the first bit again. Any ideas?
66 dodge dart 270, 225ci, 3.7l, L6
PostPosted: Tue Sep 13, 2016 11:48 am
If you cut the pod off the EGR you likely cut the sring out that holds the plunger closed. Remove the EGR leftovers completely and just bolt on a flat piece of metal.
PostPosted: Tue Sep 13, 2016 2:48 pm
yea that little stem is just loose goes in and out. Maybe I can put some epoxy on it to keep it closed? though I dont really feel any exhaust coming out from that plunger
PostPosted: Tue Sep 13, 2016 3:26 pm
Ugh. You did it wrong once already with a chopsaw. Now you propose to do it wrong again with epoxy. You're on the wrong track, dude.
Job worth doing = job worth doing right. You no longer have the opportunity to simply flip the (intact) EGR valve 180° and reinstall it, so now it's gonna be a blockoff plate or another (unchopped) EGR valve installed upside down.
PostPosted: Wed Sep 14, 2016 9:08 am
I thought I hit a triple, but instead I struck out :).
BTW, I called Chrysler/Dodge dealer part dept, gave them 3671447, and they said it is no longer avail.
PostPosted: Wed Sep 14, 2016 11:18 am
True, but http://www.ebay.com/itm/322259701794
Be sure to use a new gasket.
PostPosted: Thu Sep 15, 2016 2:42 pm
Yea I saw that eBay. But on principle I refuse to pay $9 to ship a chunk of steel. So luckily I had an L bracket, cut it down and the mounting holes just about lined up, after I enlarged them a bit. So I am good now. I hit a single. There must be someway for me to reuse the old EGR plate. Like cut everything off it, then fill the void with melted lead? then paint it red?
PostPosted: Thu Sep 15, 2016 3:52 pm
…which will harden after you pour it, then re-melt the first time the engine warms up.
PostPosted: Thu Sep 15, 2016 7:59 pm
There are lots of ways to reuse the old EGR plate, just not as a blockoff plate for the EGR holes in the manifolds.
